Changing transmission fluid
Old 10-26-2006, 07:24 PM
jakea4d2's Avatar
8th Gear
Default Changing transmission fluid
This might be a stupid question, but is there a guide on how to change the trans fluid on a 99 Disco II? I just got it back from the shop and I'd like to change it but I'm not really sure of the process.
Old 10-26-2006, 08:23 PM
Default RE: Changing transmission fluid
Quick question, how many miles on your truck and when was the tranny last serviced?
Mike
Old 10-26-2006, 09:46 PM
jakea4d2's Avatar
8th Gear
The truck has 72,000 miles on it and i bought it at 66,000 miles so I'm not really sure if the transmission was serviced by the previous owners. I had the fluid changed when I bought it but the overheat light has been coming on and in another thread it was reccomended I change the fluid. I checked it and it was a dark red color and seemed to be full. So I guess I need to change the fluid and if that dosn't work, I'll take it to a tranny shop.
Old 10-26-2006, 11:17 PM
You could have a couple things going on, tranny cooler could be restricted, internal tranny problem starting to show up or a faulty tranny temp switch.
If your fluid is dark red and doesn't have a burned smell to it, I would rule a fluid change unnecessary at this time.
Mike
Draayer
07-02-2012 05:52 PM
wrp
01-13-2012 08:58 AM
dynomite
05-11-2009 04:59 PM
ascreen7
10-04-2008 09:30 AM
herblatham
03-12-2008 10:32 AM
Quick Reply: Changing transmission fluid
