Sponsored by: CARiD
changing transmission fluid 98 disco
Old Mar 12, 2008 | 10:20 AM
herblatham's Avatar
Default changing transmission fluid 98 disco
Hey, I haven't gotten the manual yet in the mail, and i'm trying to find the tansmission fluid pan. Can anyone tell me where it is? and also I need some power steering fluid, and heard that i can use the transmission fluid is that true?
1998 Land Rover Discovery LE
119.700miles
-Herb
Old Mar 12, 2008 | 10:32 AM
Default RE: changing transmission fluid 98 disco
Haven't you been under your truck yet? Do you not know where your tranny is and all that must be done to service it? If not, you might want to have a shop do it cause with a Disco 1, it is a bugger, you need to remove the cross member and usually at least loosen the "Y" pipe, just to drop the pan.
As for your p/s fluid, your's does use Dextron 3, or you can switch to Vavolines synthetic power steering fluid. Either way, you should flush or drain the old fluid before replacing with the new.
Draayer
Jul 2, 2012 05:52 PM
wrp
Jan 13, 2012 08:58 AM
dynomite
May 11, 2009 04:59 PM
ascreen7
Oct 4, 2008 09:30 AM
jakea4d2
Oct 26, 2006 11:17 PM
