Charcoal Canister
Old May 8, 2006 | 03:07 AM
MJSVG's Avatar
4wd High
Default Charcoal Canister
My ECU works fine with the exception of it keeps the charcoal canister open, so it floods the canister, and the engine stops. If I disconect the plug to the canister, it runs great, but the check engine light comes & stays on. Can I trick the ECU too avoid buying a new ECU? Would a resister shorted between the canister plug work? Thanks for any help!!!
Old May 8, 2006 | 03:39 PM
Default RE: Charcoal Canister
Have you checked out your purge valve, could be the problem.
Mike
Old May 10, 2006 | 03:00 AM
MJSVG's Avatar
4wd High
I'll check that out. I hope that works. I don't want to buy a new ECU. Thanks
Old May 10, 2006 | 11:25 AM
ORIGINAL: MJSVG
You shouldn't have to buy a new ECU, just repair the carbon canister.
Let us know how it turns out.
Mike
Old May 10, 2006 | 11:33 PM
MJSVG's Avatar
4wd High
I already had the dealership (Reno on vacataion) replace the canister (as per their suggestion). They told me it was an ECU glitch & to replace it at $3200. The dealership in Tacoma wanted $3600 + $400 installation. Thanks
Old May 11, 2006 | 01:33 PM
Have you considered a used ECU, check out e-bay, I see them there quite often, other wise there are always people parting out trucks with good prices.
Mike
Old May 13, 2006 | 12:52 AM
MJSVG's Avatar
4wd High
I tried replacing my old ECU with a used one, and that is the one with the glitch in the canister controls. Thanks!
Old May 13, 2006 | 10:02 AM
Landzu's Avatar
You may know this, it is my understanding that a ECU needs to be
coded to the vehicle to work right.
Old May 13, 2006 | 11:03 AM
MJSVG's Avatar
4wd High
I had the dealership code the ECU. Thanks!
IronGold
Sep 12, 2014 12:15 PM
kingofvermont
Jan 19, 2012 08:59 PM
wheelgarage
Jul 5, 2011 10:47 AM
adigerol77
May 20, 2011 10:41 PM
JerrodSteph
Sep 11, 2008 09:38 PM
