charging issue
Old Mar 3, 2013 | 05:51 PM
jbkroh's Avatar
Default charging issue
ok fellas,
battery kept going down on the boy
so i figured with the cold weather battery must be weak
changed it out and everything was fine for a couple of days
today it drained again, we already put a new alt. in when he bought the
car. only have 12.2 to the battery with the car running which tells mw
alt. isn't putting out, but before i the alt. back, is there a fuse i should look for,
also the bat. warning light is not coming on.
hmmmm
j
Old Mar 3, 2013 | 06:05 PM
Your alternator is shot. Don't buy a rebuilt has a high failure rate, might want to check out the new Bosch alternators at British Parts of Utah.
Old Mar 3, 2013 | 06:29 PM
Advance Auto sells a brand new Bosch alt if you cant wait for one to be shipped to you.
Old Mar 3, 2013 | 11:59 PM
LRScott's Avatar
My 96 RR (different alternator) had the same issue. The battery would be good for a few days then it would be drained one morning. It turned out to be the voltage regulator on the alternator. It would supply just enough power for the car to run fine, but would not recharge the battery. In some cases I shut it down after it ran fine, but came back out to it and it was totally dead.
Old Mar 4, 2013 | 12:06 PM
SuperSport's Avatar
I've personally done this repair a couple times, and it works perfectly... Especially where you have a rebuilt alt that the bearings are likely good in.
There are also many other videos that show how it's done. Just search YouTube.
Old Mar 5, 2013 | 01:12 AM
Take it back. High failure rate, but maybe 2nd time will be good for you. It is under warranty.
MCKEAG
Other
Dec 21, 2012 07:36 PM
iplayblues4u
Jun 1, 2011 11:31 AM
noahsfortune
Oct 18, 2009 06:18 PM
charley_bucket
Apr 29, 2009 03:58 PM
steve
Feb 18, 2009 12:02 AM
