charging system
Old Sep 19, 2016 | 08:37 PM
Tomzsix's Avatar
Default charging system
Whats happening here?? When I start my disco 2, the alternator is kinda weak, then when I give it a quick rev, the alternator charges properly. I just replaced the drive belt 3 mos ago. What is this magic going on?? Is it a pulley or is the alternator screwed??
Old Sep 19, 2016 | 08:40 PM
mln01's Avatar
What symptoms indicate the alternator is "kinda weak?"
Old Sep 20, 2016 | 11:47 AM
d.a.r.y.l's Avatar
If you are relying on the dash gauge to tell you you have a weak alternator DON'T. JMO D*
Old Sep 20, 2016 | 08:40 PM
Tomzsix's Avatar
Not too sure about kinda weak, because battery is always charged. Maybe a pulley? Sometimes I think I hear belt slap at start up when cold. All I know is that when I first start the motor, hot or cold, the "system" is not charging and I have a low idle. Then I gun the throttle quickly, and I have a healthy Idle and charge to battery.
Old Sep 20, 2016 | 09:51 PM
mln01's Avatar
Low idle speed is not a symptom of a bad alternator.
Old Sep 20, 2016 | 11:25 PM
Mr. Moore's Avatar
it is possible that the regulator in the alternator is going bad and it has to be run up over a certain rpm to start working. You can pull the alternator off and take it in and have it tested to tell you if that is the problem or if your problem is elsewhere.
Marsalad
Nov 21, 2012 10:11 AM
nahtanoj
Feb 9, 2011 08:02 PM
steve
Feb 18, 2009 12:02 AM
maddash6
Jan 13, 2008 08:12 AM
RTLimo
Aug 15, 2005 12:42 AM
