Chassis Replacement
Old Jun 24, 2021 | 03:12 PM
Aj6543's Avatar
Default Chassis Replacement
A few questions on replacing the rear chassis replacement. Most chassis mostly just need the rear section replaced.
Chassis replacement comes in three options, rear quarter, rear half and full chassis.
1. How much can you expect to spend to replace just the rear quarter section? Its not supposed to be to complicated.
2. If you are doing the rear quarter replacement, does it make sense to do the full rear half and not just the quarter section? (Doing the full chassis I understand costs $8k to install.)
3. Why doesn't the the front rust as bad as the rear?
Old Jun 24, 2021 | 07:13 PM
Extinct's Avatar
I will attempt to answer two:
2. Rear quarter does not have suspension attachments, only structural portion is the hitch. Many shops might view that as less riskly and therefore charge less than rear half, plus there is less to unbolt. Also less risk of misalignment causing suspension alignment issues.
3. Engine oil leaks coat the front half of the frame with oil, it appears that the factory oil breather baffle had one side benefit.
Old Jun 25, 2021 | 03:59 AM
The Deputy's Avatar
The area right directly along/next to passengers side cat will rust out on frame, patched three of our four Dll's.
Yeah, the half section requires a lot more work, as mentioned, since it involves rear suspension area.
Old Jun 25, 2021 | 06:17 AM
zski128's Avatar
In Massachusetts these are the prices I have been quoted:
Full frame swap: new to me frame $1800 (800 for frame $1000 to strip and repaint plus waxoyl the inside. Then $10k -$12k to swap over. Best option if you want to fix other things along the way.
Half frame: About $6k in total including new chassis section.
Quarter frame: didn’t get an exact quote but ball park was $3k.
Old Jun 25, 2021 | 02:11 PM
frostythor's Avatar
the question is how much can you do your self, I did a quater replacement, see my post " Busy Few Days ", just the replacment party about £350 as I did it all myself, full chassis replacement in the UK are in the £3000 mark so I think the quotes you got are a bit over the top
Old Jun 26, 2021 | 01:07 AM
jayvee's Avatar
3rd Gear
https://landroverforums.com/g/album/20789703
Photos of rear frame replacement...
piperff
Mar 12, 2021 01:55 PM
Papag1313
Sep 1, 2018 05:05 PM
Fizzbiz
Dec 14, 2017 05:21 AM
Andy2Rover
Apr 13, 2017 07:48 AM
tandy807
Aug 3, 2011 11:20 AM
