Cheap-ish EFI diagnostics kit soruce
Old Oct 20, 2023 | 08:22 AM
PickleRick's Avatar
Default Cheap-ish EFI diagnostics kit soruce
Kohler part number is 24 761 01-s
Dealer cost through Kohler is 182 bucks so expect retail to be about 250ish but there is a hack. Cub cadet (mtd) buys many Kohler sourced parts at a deep discount and if you can find a cubcadet dealer the list price is @150. Kohler dealers have complained about this but seems Cub isn't required to MSRP their Kohler parts. Good for you, not good for Kohler dealers
Kohler used the Delphi or Bosch efi system which is why it works on our disco 2. This m
Not sure what most of this kit does, obviously first glance is the fuel pressure tester with nice bleed off valve to test fuel running pressure/pressure after cut off holding power.
Also has the little light to plug into your injector clip to verify it's firing off.
Likely not a kit many would need since you can rent a tester but you have a local cub dealer or can find one on the web you can get a kit that will test injector firing for about the same price you'll pay for just a fuel tester (good one not cheap china one)on eBay. Let's face it, the cheap china one will probably work great for most of us and will fit many different applications other than the Bosch/Delphi system. But if you like quality tools and tinker on rovers this might works for you
swissarmychainsaw
Range Rover Classic (1st Gen)
Sep 26, 2023 04:47 PM
Motorhead1
May 2, 2022 02:07 PM
TimInNova
Aug 30, 2020 10:18 PM
coors
Oct 27, 2014 12:44 PM
abran
Oct 14, 2014 09:09 AM
