Check engine code is...
Old Jul 30, 2009 | 12:19 PM
03WhiteDisco's Avatar
Default Check engine code is...
O2 Sensor malfunction PO150, front right side. Does this sound right? Urgent fix?
I'm finding a new O2 sensor for $125?
Also, where do I get new wiper blades?
Thanks all.
Old Jul 30, 2009 | 03:37 PM
lipadj46's Avatar
Yes do it ASAP. Atlantic British is a good place for O2 sensors and wipers. You should replace them in pairs, so replace both front ones. I'm assuming you have a DI because DII O2 sensors are $60 each. If you are above 100,000 miles think about replacing all 4.
Old Jul 30, 2009 | 03:52 PM
Thanks, I was wrong about the O2 price, I found it locally for $70. You're saying I should replace both sensors in the front rather than just the faulty one?
Old Jul 30, 2009 | 03:57 PM
lipadj46's Avatar
It is recommended to replace them in pairs unless you have recently replaced the other one. You want them to be as close to matching as possible for your engine to run properly.
FlyingZebra34
Feb 22, 2014 05:39 PM
DV57
Mar 2, 2012 06:03 PM
sayeedA
Nov 15, 2011 11:02 PM
razorbak
Feb 9, 2008 07:38 PM
rravenn13
Jun 13, 2007 08:58 AM
