Check Engine - Easy Question =)
Old 05-26-2009, 10:39 AM
unstable's Avatar
Default Check Engine - Easy Question =)
So in the course of trying to locate the leak on the DII, I removed the entire air filter tube and laid it on top of the manifold just to get it out of the way.
I went to fire up the truck and it stuttered a little but then she started...check engine light suddenly appeared, I'm assuming because of the MAP? sensor...is it going to go back to happy after I put everything together or do I need to clear the codes.
Old 05-26-2009, 10:41 AM
JBEGIN's Avatar
what were the codes?
Old 05-26-2009, 10:42 AM
Nope, you will need to get a scanner on it and clear the code.
Old 05-26-2009, 10:44 AM
unstable's Avatar
darn, I hate creating more work for myself.
@JBEGIN
I didn't read the codes as I was just searching for a leak and I needed to get a better view down into the engine compartment. I'm 99.9% sure that the check engine light only came on because I pulled the air filter tube and box off of the throttle body...
Another thing on the laundry list.
Old 05-26-2009, 12:49 PM
Night Train's Avatar
Hey
I did that on my 04 with the same result however, I did the ol' on,off three times to reset and then on the forth fired it up and drove it around the block and it went off
Old 05-26-2009, 07:59 PM
unstable's Avatar
what is this on/off on/off stuff?
Did you just turn the car on and then off 3 times in a row and then drive it around the block?
Guess it doesn't matter. I can get my hands on a scanner in the near future and just clear the code, it's changing this water pump that is turning out to be way more fun than I planned on...
Old 05-27-2009, 08:03 AM
On some, very few, faults, a few start cycles will allow the ecu to clear it self. If you are lucky, this can happen if not then you'll need a scanner.
Old 05-27-2009, 08:15 AM
AK Rover's Avatar
Pick yourself up an inexpensive scanner and keep it in the truck. That's what I do. Seems like eery trail I go on ends with my check engine light on so I just turn it off since I can't afford to fix the problem right now.
FlyingZebra34
02-22-2014 05:39 PM
72chevy
05-08-2008 09:04 PM
96SE7Disco
02-01-2008 04:21 PM
Camdisco24
10-03-2007 09:40 PM
dmonares
08-07-2006 01:30 AM
Quick Reply: Check Engine - Easy Question =)
