Check engine light and: Fault 93: evap....
Got a check engine light. Plugged in my Hawkeye total, went to read DTC: and this popped up:
Fault 93 evaporative control system fault minimum value not reached. fault present and static
A bit confused since all the check engine light codes I have seen are P01000 style. Googling does not really come up with much. Any ideas?
Thanks.
Thanks.
Cheap Elm 327 bluetooth and Torque for Iphones and Android maybe 30.00 tops - it will give you the actual pXXXX code it has no idea about LR but you can look them up from there.
For example I had 2 SAI codes (disconnected hose) P1415 and P1412 torque says powertrain multiple descriptions, the 1412 comes up as egr pressure sensor and 1415 SAI for multiple manufacturers. They are both SAI for LR.
