Check engine light and: Fault 93: evap....
Old Sep 27, 2020 | 09:38 PM
Jason_B's Avatar
Default Check engine light and: Fault 93: evap....
Got a check engine light. Plugged in my Hawkeye total, went to read DTC: and this popped up:
Fault 93 evaporative control system fault minimum value not reached. fault present and static
A bit confused since all the check engine light codes I have seen are P01000 style. Googling does not really come up with much. Any ideas?
Thanks.
Old Sep 28, 2020 | 06:45 PM
Jason_B's Avatar
Wow, crickets on this one... I am screwed if the forums don't know what is going on lol.
Old Sep 29, 2020 | 12:16 AM
Richard Gallant's Avatar
Could be the Hawkeye does it's own thing with codes which makes it hard to figure out
Old Sep 29, 2020 | 03:35 PM
Jason_B's Avatar
Well that sucks. What is the other popular scan tool? Maybe I should get one of those?
Old Sep 29, 2020 | 04:23 PM
Cheap Elm 327 bluetooth and Torque for Iphones and Android maybe 30.00 tops - it will give you the actual pXXXX code it has no idea about LR but you can look them up from there.
For example I had 2 SAI codes (disconnected hose) P1415 and P1412 torque says powertrain multiple descriptions, the 1412 comes up as egr pressure sensor and 1415 SAI for multiple manufacturers. They are both SAI for LR.
webwolf2007
Range Rover L322 (3rd Gen)
Aug 10, 2020 09:03 AM
tugbeh720
LR2
Aug 11, 2017 12:28 PM
martin08
Dec 10, 2011 08:10 PM
bartjjansen
Aug 20, 2010 05:41 PM
jcolumbia23
Oct 3, 2007 12:12 PM
