Check Engine light on idle flash on rev's wont spit codes
Ok for the basics
2003 Discovery SE "was given by Brother in law that isn't mechanically inclined in any way"
149000 Miles
Engine rebuilt at 97k
Head Gaskets / Top end done last year 2015 at 148000.
Batt is a 550cca "Switching it tomorrow to 750 cca because one in car has reversed cell and won't hold a charge"
Check Engine light is on solid on start up "by being jumped"
Any rev's to motor check engine flashes
goes solid once back at idle
new fuel in tank
Vehicle drives ok just sluggy is all no real violent shaking at all.
Cant access the obd2 codes on my snap-on scanner but scanner does power up on the OBD2 plug "If was a gmc I would think it is a fuse" Is there a fuse in the Rovers that do the same thing?
Anyone with a heads up as to the code retrieval would be a big help
149000 Miles
new fuel in tank
Well i did take it out onto a 50mph road to see what it did on Saturday and it was like nothing wrong. But coming out of a 06 Denali that's built up to me the thing was a slug bug. But i am getting good KV on all cylinders and Oil Pressure is normal. So I figure swap the battery out and see what that does first. Then side road it a bit to see if there is anything that comes up and if so Trailer queen it for the day. I will report exactly what I do find because it seems everyone has these issues but nobody really puts a final point on what fixed it other then a few Fuse Box issues "Normal Brit issue with any of their cars"
If the check engine light is flashing then you've got a miss on a certain percentage of cylinder fires. Cant remember the exact amount, but it is enough to be considered damaging to the vehicle. Misfires will melt your catalytic converters in a heart beat. I wouldn't drive it if I were you.
My obdii connector started losing connection because it is always connected to a heavy cable and is no longer in its slot (for support). I did the caveman thing and mashed the wires in from the back the connector and it came back to life. The wires may just be a little stretched.
But I THINK (just bare recollection from my parts rover that is now long gone) that group of cables goes straight to a connector on the ecm. Seems like a replacement would be easy to find at a Boneyard and you could just run them to the glove compartment or back through the dash.
importdave
09-29-2014 02:53 PM
