Check engine light and rough idle, and two codes
Old Mar 11, 2012 | 04:23 PM
cobbcj7's Avatar
Question Check engine light and rough idle, and two codes
I drove my Disco from Charlotte to Atlanta and back last week. On the ride home which is about 4.5 hours each way running 80mph the whole time, the check engine light came on. It drove fine, but today after it has sat a day or two, it wont stay idling on cold start up. If it does stay running, it very low RPM and rough idle.
Two codes are P1510 and P1551
Rave Manual give me definitions for each
P1510 IACV opening coil malfunction Short circuit to battery supply - opening winding
P1551 IACV closing coil malfunction Open circuit - closing winding
Can I fix or just get a new part?? Thanks
Old Mar 11, 2012 | 04:47 PM
Your idle air control valve is either dirty/clogged or bad.
Old Mar 11, 2012 | 05:13 PM
cobbcj7's Avatar
Is it something I can try cleaning??
Old Mar 11, 2012 | 05:44 PM
Yes, remove it and clean with carb cleaner and a toothbrush.
Clean the opening it goes in also.
Then clear the code and see if it comes back.
Old Mar 11, 2012 | 06:15 PM
It might clean up but I believe it is shot.
They are expensive so if you want to save a few bucks, call Paul Grant, his number is in my signature section, he should have a good guaranteed used one for you.
Old Mar 11, 2012 | 10:19 PM
cobbcj7's Avatar
Nooooooo!! when Disco Mike declares something dead, like my last engine, it usually is!!! bummer..
I will try to clean it and thanks for the soft let down...
Old Mar 12, 2012 | 09:44 AM
Bamberson's Avatar
I just had those 2 codes pop up as well, turns out the IACV had just come unplugged in the back. Give it a good look, I couldn't tell just by looking at it. Otherwise what discomike said and try to clean it best you can. When i did that it looked like it was paonted black on the inside, too much buildup.
Old Mar 14, 2012 | 12:08 PM
cobbcj7's Avatar
First thing I saw was loose plug in back.. and everything runs fine again.. I do have old tires that causes a shake at high speed which may have loosened that plug.. Fixed.. for now
Old Mar 14, 2012 | 04:12 PM
innzane's Avatar
Congrats on the easy fix, they are so nice.
dillhole
Feb 20, 2020 02:30 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
buick215
Jul 29, 2013 12:49 PM
mdzdisco04
Jan 24, 2013 10:20 PM
dgilaon4
Jul 7, 2009 08:45 PM
