codes and rough idle after washing engine
Old Jul 10, 2013 | 12:53 AM
buick215's Avatar
Default codes and rough idle after washing engine
The other day I washed the engine bay with a garden hose and everything was running fine that day, but the next day the service engine light came on and the truck was idling rough. Today I got the codes read and they are as follows P0150, P0174, and P1174. What do you guys think it could be? I am almost sure that the water caused the problem because of the timing. Thanks for any help and suggestions that you can give me.
Old Jul 10, 2013 | 01:03 AM
P0150 is low voltage from O2 sensor, like a short or connector full of water.
P0174 is Bank 2 lean - could be as simple as wet air filter.
P1174 is same bank outside values that ECU can compensate for. Vac leaks can also cause problems.
Old Jul 10, 2013 | 01:14 AM
buick215's Avatar
Thanks for the help. The only thing that I see is that the O2 connector and air filter would have been dry by now. Unless maybe the connector has water/condensation trapped in it and the air filter got ruined by the water. I will check those things out hopefully today or tomorrow and see what happens.
Old Jul 28, 2013 | 02:15 PM
buick215's Avatar
Which oxygen sensor is bank 2? I assume that it is the passenger side, but is it front or rear.
I checked the air filter and it was OK, I still went ahead and swapped it out for a new one that I have and the service engine light as well as the rough idle are still present.
Old Jul 29, 2013 | 12:49 PM
jfall's Avatar
It will dray out.
If OK before the wash, then it will be OK after.
Just get it hot by driving it.
When you park it outside - keep the hood open.
Hayati
Feb 3, 2015 07:47 AM
desertrover97
Jun 14, 2013 11:25 PM
RoverPete
Mar 20, 2013 01:05 PM
cobbcj7
Mar 14, 2012 04:12 PM
Kandow
Nov 2, 2011 07:39 AM
