check engine light still on
Old Dec 20, 2007 | 12:18 PM
topel98's Avatar
Default check engine light still on
I ran a diagnostic on my98 disco and it said to that I had bad O2 sensors. I changed them, reset it and the check engine light came back on 24 hours later. Any ideas?
Old Dec 20, 2007 | 12:20 PM
98roverguy's Avatar
Default RE: check engine light still on
What is the code now? Did you replace all 4 of them?
Old Dec 20, 2007 | 12:21 PM
98roverguy's Avatar
How many miles?
Old Dec 20, 2007 | 02:41 PM
topel98's Avatar
replaced all 4 of them and 84K miles on it. i haven't hooked it back up yet to see what the code reading is but am going to this weekend
Old Dec 22, 2007 | 03:19 PM
topel98's Avatar
the code is P1187 HO2S heater short circuit upstream sensor..........OK what is it and how difficult to fix.........thanks everyone
Old Dec 22, 2007 | 05:17 PM
okdiscoguy's Avatar
I posted a reply on your other thread. Did you wire these in yourself?
Old Dec 22, 2007 | 05:57 PM
Check the connection, if all is OK then call your supplier and see how he wants to warranty the replacement.
Old Jan 7, 2009 | 05:51 PM
Greenagain's Avatar
4th Gear
I also have PO441 showing up under my CHECK ENGINE Light. Is it a gas cap or valve and what are the expenses to fix, etc...
Thanks Matt Lively
Old Jan 7, 2009 | 06:19 PM
Nope, it is an incorrect purge flow.
FlyingZebra34
Feb 22, 2014 05:39 PM
ccsellers
Oct 18, 2010 09:35 PM
bcolins
Oct 7, 2008 07:19 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
