Checking the tranny fluid!?
Old May 18, 2009 | 07:39 PM
nickd503's Avatar
Default Checking the tranny fluid!?
So I recently flushed out my tranny fluid and have had trouble reading my dipstick ever since. I put the required amount back in and from what I believe im checking the fluid within all the required rules.
1) level ground
2) check when is engine is cold
3) move shifter from park through all the gears and back to park
When I check the dipstick it reads just below the bottom mark!? From what i can tell i dont have a tranny leak so this leads me to ask where in the heck is it going? Anyone else have trouble with the tranny dipstick? I would love to know how everyone else gos about checking there fluid.
Old May 18, 2009 | 07:41 PM
AK Rover's Avatar
I would say that if you're on level ground, engine/tranny cold and shifter through all the gears then you're low on fluid. You need to top it off before you do damage to the tranny.
Old May 18, 2009 | 08:04 PM
"ditto"
Old May 18, 2009 | 08:15 PM
Just because you added what was called for does NOT mean it is full.
You are only supposed to drink half a can of Pepsi, but your still thirsty so you drink the whole thing.
your transmission is the same way.
Go by the dip stick not the book.
Old May 18, 2009 | 08:28 PM
nickd503's Avatar
Makes sense. My only concern is over filling it. I was amazed at how fast that fluid will start climbing up the dipstick, it doesnt take long at all. I think i'll just drop a little bit in before i even start it and then check it and take it from there.
Old May 18, 2009 | 08:49 PM
You need to remember that the fluid sticks to the sides of the dip stick tube and that you have to wait for it to all drain down into the sump before you can get a accurate reading.
So...if it is at the "ADD" mark then add one pint, if it is just at the bottom of the dipstick then add one pint, then add half pints until full.
This whole process may take several days.
Once you get it to the "ADD" mark you can drive it.
Now get this, once you drive it and it actually shifts through all the gears the fluid level will drop again.
1998DiscoverySE
Jul 20, 2012 08:02 PM
DUBLJDISCO2
Jan 6, 2012 06:29 PM
NiteTrain
Jan 24, 2011 03:31 PM
LRScott
Mar 4, 2009 08:39 AM
jkid
Jan 26, 2008 08:11 PM
