Chirping noise/ front wheels
Old Nov 15, 2009 | 09:13 PM
Originally Posted by bookerbr
I have a 2000 Disco with 126000 miles on it and it just started chirping and making a clunking noise when I shift to drive. It sounds like it could be the drive shaft too.
STOP DRIVING THIS TRUCK, PULL OVER AND CALL A TOW TRUCK!!!!
If your front driveshaft fails you WILL be buying a new transmission.
Old Nov 15, 2009 | 09:38 PM
bookerbr's Avatar
Thanks. I have been driving it all over this weekend. I must have had some luck on my side. It started vibrated a little more during acceleration about 4 weeks ago when I had my tires rotated. I just thought it was the alignment. Now the chirping sound and the noise when shifting to drive. What do you suggest? Should I just buy a new front drive shaft?
How difficult would it be to do it myself? I have the repair manual.
Brian
Old Nov 15, 2009 | 09:41 PM
lipadj46's Avatar
Just get your driveshaft rebuilt with greasable u-joints and grease them every oil change. Do not buy a new driveshaft as they come with the non-greasable u-joints and you will be doing this again.
I have never done a rebuild but there is a detailed tutorial out there with pictures and everything.
Old Nov 16, 2009 | 08:49 AM
bookerbr's Avatar
I am looking at replacing the u joints on the drive shaft with the greasable fitting u joints. Looking at the repair manual and through the forum, it doesn't look like it is very difficult. Is there any suggestions or tips?
Old Nov 16, 2009 | 09:06 AM
Make sure you get a new centering ball too.
Old Nov 16, 2009 | 09:32 AM
So, how often do you grease your drive shaft and have you had your front shaft rebuilt yet?
Old Nov 16, 2009 | 11:33 AM
bookerbr's Avatar
I bought the vehicle with 60,000 miles and haven't greased the drive shaft yet. I haven't had it rebuilt and I am not sure if it was rebuilt prior to purchasing the vehicle. I was looking at replacing the u joints myself and was researching where I should purchase them. I was going to look into advance auto.
Old Nov 16, 2009 | 05:30 PM
Pwn777's Avatar
My truck makes a squeaking noise also (sometimes). Except when i use the brakes it stops, i dont have to worry about any of this do i?
Old Nov 16, 2009 | 05:44 PM
No DI's do not have the drive shaft failure problems that DII's do.
DII's do not have grease fitting's on the front drive shaft and with the lack of regular greasing the u-joints just wear out and fail.
It sounds to me like it is your brakes squeaking.
Either check them yourself or have them checked for wear.
Old Nov 17, 2009 | 12:17 PM
bookerbr's Avatar
Default Flexible Coupling
Do I have to replace the flexible coupling on the rear shaft? Also, there is a greasable fitting on the rear shaft U-Joint. Does this mean that it must have been rebuilt already. I thought all original shafts did not come with greasable fittings. I haven't greased it since I bought the truck 60,000 miles ago, so I might just replace it now that I have the front shaft off.
