choke cleaning
Old Apr 17, 2006 | 12:21 AM
awsherwo's Avatar
7th Gear
Default choke cleaning
97 discos come with auto chokes, and i am havinig problems with cold starts, initial idle, and need to clean it. cant find a diagram, and don't know where it is.
Old Apr 17, 2006 | 12:36 AM
esaycho's Avatar
Default RE: choke cleaning
I'm not sure about the auto choke, as the Land Rover Engines are EFI and not carbs, are you sure it's not the idle air bypass, needs to be cleaned or replaced
Old Apr 28, 2006 | 01:52 PM
I agree, you have no choke. First thing to do would be to remove the air intake tube from the throttle body, and use some carb spray and a wrag to clean out all the built up carbon on both sides of the throttle plate. Next thing to do is have someone clean your IAC motor, idle control unit.
Between these two items you should be set.
Mike
VB_Rover
Detailing
22
Nov 16, 2022 01:21 PM
Charlie_V
Oct 22, 2013 11:14 PM
Autogeek
Detailing
Feb 26, 2007 06:48 PM
05LandRover
Apr 26, 2006 10:27 AM
Rustysrf89
Oct 30, 2005 09:28 AM
