Do I have a choke?
Old Oct 22, 2013 | 05:49 PM
Charlie_V's Avatar
Default Do I have a choke?
Hello all,
2000 LR Disco II has developed an odd problem. It starts poorly and then almost dies after I back out of my driveway and put it in Drive. After about a minute it works just fine. It is acting like my old lawn mower with the manual choke. Once it warms up it runs fine all day. I have never had this issue before (and I have owned it since 1999).
I always use Premium gas. I have been through several tanks since the problem started.
This problem started after I did the top end sea foam clean, cleaned the throttle body, and cleaned the MAF. It seems to be getting worse.
Any ideas?
Best,
Charlie V
Old Oct 22, 2013 | 08:25 PM
Go back and double check your work, make sure you plugged the idle control valve back in.
Of course you dont have a choke, you know that.
Try letting it warm up in your driveway for a min or so before backing.
Old Oct 22, 2013 | 11:14 PM
Charlie_V's Avatar
I have a persistent vacuum leak somewhere that affects the recovery of my brake booster. Could that be the problem? I have my eye in the front most vacuum fitting on the throttle body. When I swapped the engine (for the same model) I had some trouble taking the tiny red ring off. Is there an o ring in there? Oh heck I'll look but it is almost surely something I did. Thanks for the input. I'll report what I find.
nelsontod
May 18, 2012 12:20 PM
USMC_Denver
Apr 21, 2009 05:58 PM
awsherwo
Apr 28, 2006 01:52 PM
05LandRover
Apr 26, 2006 10:27 AM
