CKP - Replace Before Failure
Old Feb 21, 2020 | 08:45 PM
cvhyatt's Avatar
Default CKP - Replace Before Failure?
My 2004 Disco is a daily driver. I put 50 miles a day on it going to and from work. I have some flexibility in my schedule but generally speaking, I need to have a vehicle I can count on to start up and run every morning. I got just about all the bugs worked out so I am trying to think about what I can do to be a bit proactive. I have read the CKP can fail without warning leaving you stranded. Does it make sense to proactively replace the CKP to head off a imminent failure?
Old Feb 21, 2020 | 09:38 PM
Dave03S's Avatar
In over 200k miles of ownership I've never had that fail.
Old Feb 21, 2020 | 09:50 PM
acg's Avatar
acg
Mine failed at 105K. I heard spraying cold water on the CKP can be a temporary fix if you have a sudden failure on the road.
Old Feb 22, 2020 | 01:01 AM
Discorama's Avatar
I just carry one for that reason.
Old Feb 22, 2020 | 02:07 AM
No Doubt's Avatar
I think it's bizarre that a non-wear sensor with no moving parts has reports of failures.
*but yeah, I still replaced mine when I did my engine rebuild
Old Feb 22, 2020 | 06:43 AM
cvhyatt's Avatar
Thanks guys. I should have replaced mine when I rebuilt the engine but I didn’t. I think I’d much rather replace it in my garage than on the trail so I will go ahead and swap it out.
Old Feb 22, 2020 | 10:28 AM
mln01's Avatar
And then keep the old one as a spare ...
Check out this thread from a year ago for a discussion of CKPS failure. It's not definitive but it's a good discussion, I think.
https://landroverforums.com/forum/di...t-93401/page3/
Old Feb 22, 2020 | 11:52 AM
cvhyatt's Avatar
In the interim, I will add some of my leftover DEI heat barrier to protect it as heat looks like one of the failure modes.
Old Feb 22, 2020 | 06:40 PM
Extinct's Avatar
Heat is definitely the failure mode. I wrap by cps sensor covers in aluminum foil inside and out for the same reason you put the heat shield on your floorboards.
Old Feb 22, 2020 | 09:15 PM
Boostle's Avatar
i had one fail and leave me stranded. seems like a good idea to replace at $75 or so for the part.
My starter died while i was getting gas with 152k on the odo. original starter.
i also had a fuel pump die on me on a hot day at about 145k miles.
