Ckps replacement tips
Any hints on getting to the wiring harness for the CKPS? My arm is slightly to big to reach the electrical connection. Anyway to get to it from above?
I could not find anything online that was helpful.
Thanks
Thanks
Finally got it figured out. It is imperative that you plug in the CKPS prior to mounting it to the engine. would have saved me an hour and much frustration if I did that first.
I disconnected the exhaust, three bolts, that bought me a few mm of room for my forearm. Which was actually meaningful.
Used lots of electrical connector cleaner. It would be a 30 minute job knowing what I learned about connecting the electric first.
Hopefully this helps somene down the road.
I had some really long reach needle nose pliers (I think 16in reach snap on ones) that I borrowed from a friend which got disconnecting and reconnecting the sensor plug ezpz. Probably not something most folks have laying around because those tool truck pliers are $$$$
