Cleaned/Charged battery-Got lights, No Start!
Old Nov 27, 2010 | 04:25 PM
bikeG976's Avatar
Default Cleaned/Charged battery-Got lights, No Start!
2001 Disco II 102K - The other day I re-wired my rear fog lamp, turned the lights on many times without actually starting the truck to check the lights as I was working on them (rear fog still not working) The next day the truck was dead. I cleaned the batter posts real good and charged the battery. Changed the oil real quick, greased the D/S and found a coolant leak during the charge. After the oil change and a full charge I went to start the truck and got nothing. I checked all fuses and tried again. All the interior/exterior lights work, all dash lights come on but the engine does not turn. The last time I tried it, I had the key turned to the ON position and all my dash lights were just flashing. I have never seen this and have no idea what I did that the truck is not starting at all now. Need it by tomorrow. Any ideas?
Thank you,
Old Nov 27, 2010 | 09:57 PM
novadisco2's Avatar
Sounds like you've lost a ground. Have you tried boosting it or metering the battery? How the positive connection at the starter? Mine was like that when I first picked it up, it had been stored for years, plopped a battery in it and I had nothing but flashing lights. Cleaned a bunch of grounds, and the main power, then replaced the terminal for the ground at the battery. started right up after that! good luck!
Old Nov 27, 2010 | 10:09 PM
maxman's Avatar
I've had that same sort of problem. For me it was just a bad connection at the battery, it would pass enough current to turn on the lights, but not the starter. All I did was tap the battery terminals with a hammer (don't judge) to drive them a little further onto the tapered posts and BAM. Away I went.
Hope this helps.
~Max
Old Nov 28, 2010 | 10:34 AM
Have you tried jumping the battery with a good one? Have you tested to see what sort of voltage you have, have you tried jumping a hot cable to the starter and try starting it?
Old Nov 28, 2010 | 11:06 AM
bikeG976's Avatar
Bad grounds. Up & running now. Thanks!
Old Nov 28, 2010 | 12:32 PM
novadisco2's Avatar
Glad to hear! I thought so!
tom_mccallum
Apr 16, 2010 06:39 AM
Willie00d2
Feb 15, 2010 12:45 PM
Alex J
Jan 12, 2010 07:54 PM
brianb883
Sep 13, 2009 09:46 PM
EVN137
Jul 8, 2007 08:21 PM
