Cleaned my blower motor - where'd this stuff come from?
Old Oct 23, 2016 | 12:27 AM
huggi's Avatar
Default Cleaned my blower motor - where'd this stuff come from?
See the attached pic, how did all this stuff get in there?
Old Oct 23, 2016 | 12:50 AM
Dave03S's Avatar
check your plenum filter. probably needs replacing.
Old Oct 23, 2016 | 09:52 AM
huggi's Avatar
Yea it's missing, need a new one. Thanks Dave
Old Oct 23, 2016 | 11:28 AM
samue23's Avatar
Default Blower Motor
How difficlut was it to get to it and remove/clean?
Old Oct 23, 2016 | 03:29 PM
The_OGCJR's Avatar
Plenum filter? lol I never had one! I broker my plastic plenum stuff all to **** when doing headgaskets. First I need that.
But yeah the intake for that is on the passenger side below your wipers
Old Oct 23, 2016 | 05:17 PM
huggi's Avatar
Pretty easy, took about 45 mins - used this as a guide. Just need a T20 torx bit for your screw driver. Just remember the blue plug unplugs away from you.
https://landroverforums.com/forum/di...llation-55530/
Old Nov 4, 2016 | 03:39 PM
JUKE179r's Avatar
I'm doing this next!
Old Nov 4, 2016 | 10:16 PM
Charlie_V's Avatar
The reason the leaves get in is failure of the filter that spans the air intake just under, and entirely across, the hood.
Go to Lowes or Home Depot and get a cut to fit filter (blue material, about an inch thick). Cutstrips, strips (I don't remember precise width of cut but it will be obvious), use some pliers to work off the retainers, and put the strips in. Replace the clips. No more leaves.
One cut to fit filter is enough to do about 10 land rovers. Costs about 8 bucks.
Rovernewb15
May 11, 2016 02:19 PM
vonrock
Jan 4, 2016 05:55 PM
Cosmic88
Mar 9, 2011 06:53 AM
phidelt583
Dec 29, 2010 11:04 PM
