Cleaned TB per instructions, now engine is locked
Cleaned the throttle body exactly as described on this site's How To thread & now the engine is acting hydro-locked. The starter turned for about 1 second & "CHUNK"... Now that's all I get.
WHAT IS UP?!?!?
WHAT IS UP?!?!?
like someone else said, change your oil, look for metal in the filter and drain pan, reinstall the plugs and start the engine.... if you hear a clunk i think you might need a new starter, with the engine without pulgs it would be much easier to turn over and since it did turn over with no clunk, that rules out the rotating assembly being the cause of the noise....
but you must change your oil ASAP and try the starter again with plugs in the engine
