Clearing ABS codes
Old Jul 20, 2013 | 03:05 PM
FlyingZebra34's Avatar
Default Clearing ABS codes
Can it be done without the scanner?
Someone said you can short 2 connectors to get them to clear
Old Jul 20, 2013 | 03:49 PM
Why would you want to clear them with out fixing it? And the answer is no, they can't be cleared without the proper scanner or computer.
Old Jul 20, 2013 | 05:06 PM
The code is a weak signal on back right wheel. Part is swapped but I need to clear it I believe and don't have a tool nor do I want to drive 100 miles to the dealership.
Thank you though, I'll see if anyone is willing to let me borrow the amigo.
Old Jul 22, 2013 | 02:15 PM
jfall's Avatar
weak signal on back wheel - you can get a screw driver on a Discovery I and pound on the sensor to move it a bit toward the toothed reluctance on the hub and the weak signal goes away.
Not sure if this works on Discovery II.
On Discovery I the sensor is just in via friction.
Old Jul 22, 2013 | 05:53 PM
Still won't clear a 3 amigos set of lights, takes a scanner.
tsuami1
Jul 1, 2010 07:02 AM
Aj6543
Nov 27, 2009 09:27 PM
wetheww
Sep 27, 2008 08:41 AM
Phototone
Mar 31, 2008 01:06 PM
pilsner
Jan 12, 2008 07:32 PM
