CLEARING CODES AFTER SEAFOAM?
Reading old posts here....newby to Land Rover Discovery. I have a 1994 Disco. In shop now for brake line repair (leak) Haven't driven it hardly at all yet, due to almost no brakes due to one circuit leaking.
Considering the SeaFoam induction treatment. An old post remarked that doing the treatment might result in some "codes" that would take a code reader? to clear? Don't have anything like that here. Fairly good shadetree mechanic skills (on older vehicles). Whats the story here? Can I clear codes myself without any further equipment than normal light shop tools and electrical test equipment?
on
RE: CLEARING CODES AFTER SEAFOAM?
As long as you do the induction properly, you should not trip a code, and if you do, you can clear that code your self if the ECU doesn't clear it after 5 or 6 start cycles.
Do you know how to do the induction cleaning, mighty also flush your crank case and clean the throttle body at the same time.
ORIGINAL: Disco Mike
tsuami1
07-01-2010 07:02 AM
