Click click click sound
Old Apr 26, 2019 | 07:02 PM
rcdoeshair's Avatar
Does your front drive shaft have a spot to grease the internal bearing of the cardan joint? Normally, you have to drop the upper end and move the cardan joint around to expose the grease zerk (which will most likely be a small indentation and takes a special grease fitting to apply grease).
Have you checked your transfer case fluid?
Brian.
I have not checked the transfer case fluid yet, I somehow lost my 1/2" 6" extension so have to make a trip to Harbor Freight (over an hour away) to get one. In the back of my mind, I'm really thinking that's what it is.
As far as the zerk fitting in the double cardon joint, I honestly don't recall seeing one today when I took it off but I will double check tomorrow.
Old Apr 29, 2019 | 03:47 PM
rcdoeshair's Avatar
Ok, so I was able to finally check some things out. I was about a quart low in the t-case, so I filled it up then I got excited because I didn't hear anything. Then today, all of a sudden it started again.
I checked my front driveshaft and do not see any fitting at the double cardon joint. It sounds as thought its coming from the middle to front of the truck. Both differentials have just enough fluid to drip out, so fluid wise, they are ok.
I jacked up the front and tried to wiggle/pry both front wheels and there wasn't any play there. So..... I'm back at a loss
Old Apr 29, 2019 | 04:13 PM
Saturnine's Avatar
Do you have CDL?
You can remove the front shaft all together and engage the CDL and still drive around in 2wd -- I did this for a few weeks while diagnosing my front shaft going caput. This lets you rule out the front shaft all together if that is the culprit
Old Apr 29, 2019 | 04:14 PM
rcdoeshair's Avatar
Originally Posted by Saturnine
Do you have CDL?
Ahhhhhh I do have CDL. I didn't even think about doing that. I'll have to do that in the next couple of days. It's supposed to rain so should be a few good days to be in the garage!
Twjones
Mar 29, 2015 07:35 PM
srockrae
Dec 21, 2013 09:53 AM
srockrae
Oct 3, 2012 09:06 AM
richief556
Jul 6, 2010 09:39 AM
snorlax
May 8, 2008 12:06 PM
