Clicking with Diff lock
Old Oct 6, 2021 | 06:13 PM
quaintmercury's Avatar
8th Gear
Default Clicking with Diff lock
I have an '01 disco 2 with the CDL linkage put in as well as a 2 inch OME lift. I have noticed that when I have the center diff lock engaged on the trails there is a clicking/clunking sound if I am turning sharply. I have a front drive shaft with greaseable u-joints that are greased regularly and have inspected to see if I can find anything wrong. The transfer case oil was also changed recently. Is this sound normal? Any idea what it could be?
Old Oct 6, 2021 | 06:17 PM
Harvlr's Avatar
If you are driving on a non-slippery surface that would be a normal sound, but you’re putting a lot of unnecessary strain on your drive train doing that. If it makes that sound when you’re on a slippery surface it could indicate a problem.
Old Oct 6, 2021 | 06:37 PM
8th Gear
The surface would be like gravel or dirt.
Old Oct 7, 2021 | 01:49 PM
Harvlr's Avatar
I’m not the expert but I think you should probably disengage the CDL when turning very sharply.
srivera2010
Mar 24, 2011 10:32 AM
CANAMDiscovery
Jul 20, 2010 09:41 PM
tango123
Feb 24, 2009 03:36 PM
handsome rob
Feb 14, 2007 07:15 PM
JRdisco1
Dec 28, 2005 04:57 PM
