Clicking from down under
Old Nov 29, 2018 | 02:21 PM
Nosugar0carbs's Avatar
Default Clicking from down under
2004 discovery 175k miles. My concern is, only when the ambient temp or cabin temp is cool/cold, I get a clicking from the BCM. With the clicking comes a few issues like fog lamps shut off, the shifter lights flicker, turn signal operate sporadic(sounds like a double click without illuminating),door latches don’t actuate and lastly is the shifter lock wont disengage. If I remove all the relays from the front of the BCM it still clicks internally. Are there serviceable relays on the backside/inside the BCM?
Old Nov 29, 2018 | 09:13 PM
Extinct's Avatar
Don't think so, sounds like you have a cracked solder joint. Cold temps probably result in shrinkage in the joint, resulting in open circuit. You might be able to take the cover off and look at the solder joints and find the bad one under a loupe.
Old Nov 30, 2018 | 07:42 PM
Sound logical, I didn’t think it was the xyz switch since I don’t get an error from PRND321 and on screen. I didn’t think it could be a brake switch since it happens with the other concerns. From just thinking, It seems to be a power/ground miscontact at the BCM. Let’s see if I can get it out and apart soon. Thank you for the theories
escott16
Dec 28, 2018 05:36 PM
Derek Gjessing
Jul 7, 2018 02:03 PM
Charlie Black
Apr 2, 2018 04:47 PM
bcbp
Aug 12, 2012 05:12 AM
sean smith
Dec 14, 2011 12:42 PM
