Clicking noise
Old Nov 27, 2023 | 10:46 AM
Robertmcell's Avatar
Default Clicking noise
So I found where the clicking noise is coming from. It's a box under the truck that's says WABCO
any thoughts
Please advise
Thanks
Old Nov 27, 2023 | 11:12 AM
mollusc's Avatar
Under the left side of the truck, about halfway along? That sounds like it's the compressor for the air shocks.
Old Nov 28, 2023 | 04:53 PM
TimInNova's Avatar
It's the ABS pump. They all make that sound. I don't know why, but I'm sure someone here does and will chime in.
Old Nov 28, 2023 | 05:55 PM
Extinct's Avatar
Could be both. If it was originally an SLS truck then the Wabco compressor valves will actuate and run the battery down. You can pull the relays and unplug the compressor to reduce the load. I do remember wiring a jumper on one of my trucks to eliminate the draw. Or you can use a Nanocom to turn off the SLS function and it will not do that anymore.
Old Nov 29, 2023 | 08:11 AM
mollusc's Avatar
That's not under the truck.
Robertmcell
Dec 7, 2023 06:48 PM
Robertmcell
Nov 17, 2023 04:57 PM
Invictus
Nov 22, 2021 11:31 PM
KernowDiscovery
May 30, 2014 10:44 PM
pickps
May 14, 2007 12:42 PM
