Clicking noise
Could be both. If it was originally an SLS truck then the Wabco compressor valves will actuate and run the battery down. You can pull the relays and unplug the compressor to reduce the load. I do remember wiring a jumper on one of my trucks to eliminate the draw. Or you can use a Nanocom to turn off the SLS function and it will not do that anymore.
KernowDiscovery
May 30, 2014 10:44 PM
