Clicking sound at low speeds
Old Jan 6, 2014 | 09:57 PM
dbeard's Avatar
Default Clicking sound at low speeds
So recently I've been experiencing a clicking sound at low speeds while accelerating, gets less noticeable at faster speeds, and the returns as the vehicle is coming to a stop. The noise can be felt in the in the e brake handle. I have removed the front driveshaft, which has stopped the noise. This is a Tom woods double cardan driveshaft. Its about 1.5 years old. Upon inspecting the drive shaft after I removed it, everything appears to be ok, except for a torn piece of the dust seal that is hanging loose around the centering ball. Nothing appears to be binding or grinding, or anything remotely noticeable. That being said, I'm no driveline expert.
Vehicle seems to drive normal with front driveshaft off. I do notice a loud clunk when shifting back and forth from drive to reverse.
So, what's my next move? Rebuild the driveshaft I bought less then two years ago? If so, does anyone have any resources on rebuilding a TW driveshaft.
Old Jan 6, 2014 | 10:44 PM
dusty1's Avatar
I assume that you have been greasing the shaft, right? 1.5 years isn't that long... While you have it out, you can go ahead and check out the output flange also.
Old Jan 7, 2014 | 07:38 AM
dbeard's Avatar
I thought I was doing a decent job at greasing the shaft, but I never did get a chance to hit the centering ball. After all the reading I've been doing, and a little more experience at pulling the shaft on and off, I'm regretting not greasing more often, and taking the time to find the zerk for the centering ball. What signs should I look for that the centering ball is shot? Also, what should I look at on the output flange?
Old Jan 7, 2014 | 09:59 AM
dusty1's Avatar
just make sure nut is tight and flange only goes round and round, no linear movement. (kind of like checking a hub)
I get lazy and don't grease that center ball as often as I probably should... but I hit it a couple times a year. no problems
tw ujs are 1310
and here is some healthy reading on the centering ball
https://landroverforums.com/forum/di...veshaft-51765/
Old Jan 10, 2014 | 09:27 AM
dbeard's Avatar
Thanks a bunch Dusty. I'll check the flange this weekend, and let you know how I make out.
Old Jan 10, 2014 | 12:37 PM
drowssap's Avatar
even if you did not religiously grease it every oil change you would think the joints would last longer than that, you factory joints were only greased once and last longer than 1.5 years.
Old Jan 10, 2014 | 02:00 PM
04duxlr's Avatar
I haven't greased the centering ball in my driveshaft in the 2 years I've owned the truck. I bought it with a rebuilt driveshaft. I tried once but couldn't seem to find the right approach with the grease needle. I tried to find the thread from Antichrist where he provides specific directions but had no luck. If anyone has been able to grease the non-greaseable centering ball I would be very appreciative of any tips you can offer.
Old Jan 10, 2014 | 04:56 PM
dusty1's Avatar
Gotta drop that end and articulate the dc, then you will see it with ease.
Old Jan 10, 2014 | 07:17 PM
primussucks's Avatar
Get one of these.
Drive Shaft Socket Wrench Tool - Land Rover Drive Shaft Tools
and a ratcheting 9/16 box wrench and it will save you a whole lot of beer and time. Easy job with the right tools.
SCIGONE
LR2
Nov 26, 2018 12:09 PM
Chris Miller
Jan 10, 2013 07:50 PM
bhorwhat
Jan 13, 2010 02:15 PM
VikingDiesel
May 17, 2009 10:27 PM
klh113
Sep 18, 2007 10:34 AM
