winshield wiper will not go back themselves in LOW speeds
Old May 13, 2009 | 09:26 PM
VikingDiesel's Avatar
Default winshield wiper will not go back themselves in LOW speeds
so if i use LOW speed windshield wipers, i have to manually hold the stalk to use the wipers unless it MEDIUM or FAST which works fine, any ideas
Old May 14, 2009 | 05:46 AM
mordor110's Avatar
What year Disco? I've got ALMOST the same problem and have been meaning to post this also. So anyone have any ideas? I was wondering if there's a relay somewhere or something? Mine don't go back on intermittent either, well they go back, but it's very jerky & slow. Low speed is OK until I turn them off, then they don't return to "home" position. I only have slow & fast on mine so I'm assuming you have a newer Disco than me.
& FYI Viking, I was using the hold the stalk option to make mine return home (bump them home) while using intermittent and it popped my fuse after doing for a while, so keep that in mind when you're using yours. I quit doing that now.
Old May 14, 2009 | 08:56 AM
You both are most likely dealing with a failing wiper switch, not a relay.
Old May 17, 2009 | 10:27 PM
mordor110's Avatar
Thanks Mike. The parts Disco I bought last week will pay for itself in misc switches alone I think as I have several that are failing or have intermittent issues. My hi-beam flash quit working last year, and a few of the ones around the instrument cluster binacle you have to fiddle with/push really hard to get them to work.
Chris Miller
Jan 10, 2013 07:50 PM
Deltahf_2
Nov 4, 2011 11:54 AM
bhorwhat
Jan 13, 2010 02:15 PM
TheUninformedOwner
Freelander
Jul 16, 2009 04:48 PM
klh113
Sep 18, 2007 10:34 AM
