Clicking sound from steering wheel when turning
Old Oct 13, 2014 | 08:45 AM
aguison's Avatar
Default Clicking sound from steering wheel when turning
Dear D2 forum
There's a clicking/ratcheting sound coming from my steering wheel during turning. It's not coming from outside the car, definitely coming from the inside of the car from the steering wheel column. I've removed the three screws holding the two pieces of plastic covering the steering wheel and visually can't identify root cause of the noise.
Has anyone encountered the same issue? Any suggestions?
Thanks as always
Al
2003 D2 SE7
Old Oct 13, 2014 | 11:58 AM
Paul Grant's Avatar
Sounds like an issue with the rotary coupler. Is everything else working well that's associated with the steering wheel (ie. volume switch, cruise control, horn)? Was the wheel recently removed and/or replaced as the coupler could have been damaged if it was installed improperly when the wheel was replaced.
Old Oct 13, 2014 | 12:01 PM
aguison's Avatar
Yes, everything with the steering wheel is working. Volume switch, cruise control, and horn.
Yes the wheel was recently replaced.
BTW Paul, if it's this rotary coupler, can you send me a pic and how much for this part?
Al
Old Oct 13, 2014 | 12:03 PM
Paul Grant's Avatar
Well, it sounds like you may be fortunate enough to not have damaged the coupler but I would either remove the wheel and reinstall or get it back to whomever did the work and have them do it because something is not right with the installation.
Dlk0099
Jul 8, 2021 05:37 PM
jeff spahn
Jul 20, 2018 12:18 PM
TRIARII
Aug 30, 2014 06:00 PM
cheqbay1997
May 6, 2014 10:09 AM
domyo
Sep 25, 2008 12:19 PM
