Clock
Old Dec 27, 2007 | 08:02 PM
jgbufton's Avatar
Default RE: Clock
Lamp is 1.2 watt, get from radio shack $1.50 I think I paid you just need to make sure the wires are facing the correct way and to get the old lamp out drill a small hole in the bottom of the holder and push out the old lamp, this saves a few stiches as the glass breaks, and pry the clock unit out from the under side where the two tabs are.
And remember bulbs grow and lamps glow
Happy New Year
Old Dec 28, 2007 | 12:03 PM
jmt's Avatar
jmt
Default RE: Clock
Do you have a part number on that light?
Old Dec 28, 2007 | 01:02 PM
okdiscoguy's Avatar
Default RE: Clock
I am telling you guys to call the dealer. It comes with the holder, and unless you make $5 and hour, get the right one. The assembly is a little tricky and you won't want to pull it again...
Old Dec 28, 2007 | 01:18 PM
zerochills's Avatar
Default RE: Clock
2nd that get, it from LR
Old Dec 28, 2007 | 03:21 PM
jmt's Avatar
jmt
Default RE: Clock
Sorry, I was asking about the part number on the light from the dealer. If it needs to be ordered, I want to make sure it's the right one.
Old Dec 28, 2007 | 03:47 PM
jgbufton's Avatar
Default RE: Clock
RTC3635, roversnorth(RNE673), this is without the holder.
Old Dec 28, 2007 | 04:01 PM
okdiscoguy's Avatar
Default RE: Clock
ORIGINAL: jmt
call them to make sure they have it.
Old Dec 28, 2007 | 05:51 PM
Default RE: Clock
http://www.roverparts.com/TechTips/C...eplacement.cfm
Old Jan 4, 2008 | 09:12 PM
indianadiscovery's Avatar
5th Gear
Default RE: Clock
I don't know if it was the best way to do it, but I had the same problem and used two butter knives (hillbilly, i know) and removed the clock. I have yet to get the replacement bulb, but it was pretty simple to get it out.
There is a post on here somewhere that leads to a link on how to remove it. When I take it out again, I'll snap a few pictures and send them.
Old May 19, 2008 | 11:06 PM
99LRDisc's Avatar
Default RE: Clock
http://www.roverparts.com/Parts/BAU5311L.cfm
BULB AND HOLDER CLOCK
Item: BAU5311L In Stock! $6.95 Fits: Discovery I | '94 - '99 [/align]
