clunking d2
Ok this is not a normal clunk. the same problem as the other post. my question is how does atf fluid in the t-case work and why atf and not gear oil as it is a gear box? I have 01 d2 with 54k just did tranny ,diffs ,plugs engine oil did not do t-case as atf made no sence? the problem is only when driving freeway speeds and only when cruising. Any help. thnx.
I dont know? like the other post on clunking it is a puzzle. She shifts smooth and firm when in town but once on the freeway and after a few miles 5-10 when trying to hold a constant (say 70mph) every time I let the gas and back on it feels like being smacked from the rear.???? the front drive shaft is new I had a LR tec tighten the rear drive shaft and check all u-joints. So t-case ?? . Does the 2001 d2 have a viscous coupling in the t-case?? If so when the rear drive shaft came loose (front bolts) could that have damaged it. HELP. thanks
ORIGINAL: Sean Emblin
If you figure out what the issue is before then definitely let me know!!
Piotr
on
Have you greased both the drive shafts slip joints, if not pull the plugs and grease them well. Do you have a roto flex rear connection to the rear diff, is it cracked?
All Rover, Ful Time 4X4's, have a small amount of klunk, if your's has more than you may, if you have CDL want to remove one drive shaft at a time and drive on just one,see what happens.
Mike
Mike
trangle23
11-20-2006 12:39 PM
tobob1
10-03-2006 11:37 AM
MaxColee
06-25-2006 09:49 PM
