Clunking when turning??
Old Aug 28, 2007 | 08:22 AM
chargersfan's Avatar
Default Clunking when turning??
When I turn to the left or right I get alot of clunking and a little resistance. It starts to happen when I turn the wheel 1 1/4 turns. Any ideas, I was thinking cv joints, but wouldn't I hear that even when going straight? The transfer case is in 4 high
Thanks
Brian
Old Aug 28, 2007 | 09:01 AM
Default RE: Clunking when turning??
I would suggest you have a friend sit in your truck and turn the wheel left and right while you crawl under the fron end and listen. You can be looking at any of the body bushings, tie rod ends oe any of the steering componets including the shaft from the steering wheel to the gear box.
Old Aug 29, 2007 | 07:54 AM
Couldn't test it last night, I went for a short drive and it didn't do it. Seems to only happen after it is warmed up.
I had another scary situation though while I was pulling out of the driveway at the grocery store, the brakes would not stop I was pushing very hard on the pedal and it was barely slowing down. After that they worked fine? I haven't done the brakes yet. Any ideas?
Old Aug 29, 2007 | 08:39 AM
okdiscoguy's Avatar
Not sure what year you have, or what the mileage is. I would lift the front tires and see if they have any play. Loose wheel bearing could do it. Might make a caliper hang. Be sure to block your rear wheels and lock the T-case when lifting.
Sean Emblin
Aug 16, 2016 09:06 PM
piotrsuw
Mar 9, 2007 06:31 PM
trangle23
Nov 20, 2006 12:39 PM
tobob1
Oct 3, 2006 11:37 AM
MaxColee
Jun 25, 2006 09:49 PM
