Clunks when I shift into drive or reverse
Old Feb 8, 2010 | 12:14 PM
Prowler9876's Avatar
8th Gear
Default Clunks when I shift into drive or reverse
Hi,
96 Discovery, when I shift into drive or reverse the car clunks. This only seems to make the noise when the car is warmed up, after I drive it for a long period of time.
The transmission is very smooth otherwise. Is this normal?
Thanks
Old Feb 8, 2010 | 12:26 PM
BIG's Avatar
BIG
Have you checked your ujoints?
Old Feb 8, 2010 | 01:05 PM
NiteTrain's Avatar
does it happen when its parked on a steep incline/decline?
Old Feb 8, 2010 | 02:24 PM
lipadj46's Avatar
Some clunks when shifting from P to D is normal as there can be a bit of slack in the driveline. Definitely check your driveshaft ujoints especially if they have not been greased regularly.
Old Feb 8, 2010 | 02:49 PM
hilltoppersx's Avatar
+1 lipad... slacky driveline, grease those U joints
Old Feb 8, 2010 | 04:33 PM
8th Gear
It seems to happen on a hill or on a level street. I will take it to the mechanic and have him look at the U joints. Will greasing the U joints take care of this if they arent too far gone?
Thanks again!
Old Feb 8, 2010 | 04:58 PM
NiteTrain's Avatar
it's probably going to need more than just grease. Why don't ya crawler under it and see if there is any play in the ujoints? Owning a 14 year old rover is going to get REALLY expensive if you take it to the mechanic for every little thing.
Old Feb 8, 2010 | 05:53 PM
scubasteve's Avatar
I have similar issues, but it doesn't really matter the type of surface and it doesn't happen all of the time... When I had the truck up on a lift, I inspected the entire driveline and did notice that the front shaft did have a little bit of play (rotational, not forward-backward). I keep the joints lubed religiously since Land Rover replaced the front driveshaft some 20K miles ago with a stock shaft. Interestingly enough it does have 3 lube fittings in the front driveshaft. Maybe time to replace it?
I really don't know what I'm looking for to inspect the U joints. I've replaced them before on a truck I used to have. I just need to know what to look for. Also, on the rear shaft, that rubber thing: it doesn't have any cracks, but I haven't replaced yet in the 70K miles I have put on the truck over the years. Just rolled 100K the other day...
Any information would be great!!
importdave
Sep 25, 2014 10:18 PM
PITTDISCO
Feb 1, 2013 07:02 AM
mirko_gardilcic
22
Nov 3, 2009 10:49 AM
ajh
Aug 22, 2007 05:30 PM
