clutch oil
Old May 12, 2009 | 02:32 PM
crainb45's Avatar
Exclamation clutch oil
Clutch went soft on me on way to work today and going to limp home tonight. Checked fluid level and very low. What fluid should I fill it with? Is there a best one on the market?
Old May 12, 2009 | 02:46 PM
You have a hydralic clutch, so most likely DOT 4 brake fluid.
Do you have your owners manual, it will tell you for sure.
Old May 12, 2009 | 02:58 PM
antichrist's Avatar
Castrol GTLMA. Be sure to check your brake master cylinder as well. Both should be a minimum monthly check. For the clutch I'd check more often as you may have a leak. I replaced my master and slave 2 years ago and I haven't had to add any between flushes.
Old May 12, 2009 | 04:12 PM
crainb45's Avatar
No owners manuel and just bought it recently. 95 disco 1 v8i
Old May 12, 2009 | 06:36 PM
Brake fluid, buy a quart of it and keep it in the truck until you can get the leak fixed.
buttocks
Dec 31, 2014 12:53 AM
parks
Feb 23, 2005 04:11 AM
parks
Jan 31, 2005 12:21 PM
Si
Jan 2, 2005 11:36 AM
lugo35
Engine & Internal
Dec 13, 2004 05:51 PM
