Code 1171, 1174, 0130,0171 help?
no thats prob the pump feed lines. try taping them up with electrical tape. if most of it is still there this should work for the purposes of diagnosis.
however, i dont believe this could cause the lean codes. unless they are the type of code that suggest the opposite of what the problem is. essentially the computer is saying, "ive pulled all the fuel i can but the engine is still running rich". I fought the same "lean" codes but i could never get a definitive answer on whether they were telling me that the engine is in fact running lean despite the computers tuning as rich as possible, or that the engine is running rich, despite the computer tuning as lean as possible.
actually, the P030 code is a sensor malfunction and the 071 confirms this. the P1171 and P1174 are fuel trim out of whack. So its most likely the up stream sensor. Check for bad wires on the front o2's and fix as necessary. install Walker o2's if you cant find any wiring issue.
Ok.. electrical taped that line and it looks good. Went under truck to check out the upstream bank 1 o2 sensor and plug has oil all over it. Can't check workability till I get her up on some ramps for easier access. A little tight under there!!! Anyways, looks like oil is coming from valve covers. I'll try and see if I can tackle that project soon. Thanks for the help! This site is a great asset!! If I don't feel comfortable handling the valve cover gasket change about how much does a shop charge for this fix?
