Code 1171, 1174, 0130,0171 help?
Old Jun 28, 2017 | 02:32 PM
Nysptsman's Avatar
6th Gear
Default Code 1171, 1174, 0130,0171 help?
Truck seems to be running fine but is throwing these codes. New to the forum and have been reading a lot. 2004 discovery 2 with 90,000. Cleaned MAF cleared codes and codes came back. What next? Upper o2 sensors? Or replace the MAF?
Old Jun 28, 2017 | 02:58 PM
LR03NJ's Avatar
Tey clean maf, let it dry completely. If not replace with original bosch part. Then check codes if o2 code disappears in time.
Old Jun 28, 2017 | 04:05 PM
mln01's Avatar
Those lean codes very often indicate vacuum leaks. Check for that before throwing parts at it.
Old Jun 28, 2017 | 04:28 PM
Nysptsman's Avatar
6th Gear
Cleaned MAF already. Was looking at hoses for vacuum leaks... found that the secondary air flexible hose is shot! Will this cause those codes? And if it can throw those codes why Does that hose cost over 100 bucks? Is it made of gold???
Old Jun 28, 2017 | 04:44 PM
KingKoopa's Avatar
To which hose are you referring? The corrugated metal tube that connects the Sai solenoids to the head? Robber line that feeds the solenoids? Or the vacuum line that actuates the solenoids?
Old Jun 28, 2017 | 04:50 PM
Nysptsman's Avatar
6th Gear
It looks like a ribbed plastic line. Really brittle. I just got those codes and this line looks like it has been **** for months.
Old Jun 28, 2017 | 04:51 PM
Nysptsman's Avatar
6th Gear
I would guess that it's the vacuum line.
Old Jun 28, 2017 | 05:07 PM
Nysptsman's Avatar
6th Gear
Actual name is...secondary air flexible hose
Old Jun 28, 2017 | 05:11 PM
KingKoopa's Avatar
no thats prob the pump feed lines. try taping them up with electrical tape. if most of it is still there this should work for the purposes of diagnosis.
however, i dont believe this could cause the lean codes. unless they are the type of code that suggest the opposite of what the problem is. essentially the computer is saying, "ive pulled all the fuel i can but the engine is still running rich". I fought the same "lean" codes but i could never get a definitive answer on whether they were telling me that the engine is in fact running lean despite the computers tuning as rich as possible, or that the engine is running rich, despite the computer tuning as lean as possible.
actually, the P030 code is a sensor malfunction and the 071 confirms this. the P1171 and P1174 are fuel trim out of whack. So its most likely the up stream sensor. Check for bad wires on the front o2's and fix as necessary. install Walker o2's if you cant find any wiring issue.
Old Jun 28, 2017 | 05:52 PM
Nysptsman's Avatar
6th Gear
Ok.. electrical taped that line and it looks good. Went under truck to check out the upstream bank 1 o2 sensor and plug has oil all over it. Can't check workability till I get her up on some ramps for easier access. A little tight under there!!! Anyways, looks like oil is coming from valve covers. I'll try and see if I can tackle that project soon. Thanks for the help! This site is a great asset!! If I don't feel comfortable handling the valve cover gasket change about how much does a shop charge for this fix?
bosshogt
Jan 20, 2014 09:29 PM
BIG g
Aug 11, 2010 06:16 PM
DEEBEE060
Aug 19, 2009 04:39 PM
dewhorse
Oct 29, 2008 01:00 PM
tailchaser0527
Oct 18, 2008 05:54 PM
