Code 1171 and 1174 Help Needed
Old Aug 10, 2010 | 11:28 AM
BIG g's Avatar
Angry Code 1171 and 1174 Help Needed
I keep getting codes 1171 and 1174 about every 20 miles that I drive. I've replaced the MAF sensor but still get the error codes. It occansionaly also gives a misfire code for cylinders 3, 5 or 8. Lost as to what to do next. PLEASE HELP ....
BIG g
2000 DII 114,000 miles
Old Aug 10, 2010 | 03:22 PM
hilltoppersx's Avatar
when was the last time you did a maintenance on your truck? what type of MAF did you install? was it a Bosch MAF in a Land Rover box? are you running high octane fuel only? do you have 8mm magnecor wires? bosch +4 plugs?
Old Aug 10, 2010 | 11:02 PM
BIG g's Avatar
At 91,500 I had the heads rebuilt, new Bosch 4+ plugs, Magnecor 8mm wires. At 112,000 I replaced all 4 oxygen sensors (the ones from Atlantic British) because I was getting O2 errors. Shortly after the oxygen sensor replacement I started getting the 1174 and 1171 errors. I replaced the MAF (Bosch one from Atlantic British). Did nothing to fix the errors. The frequency is much shorter between codes now. Today I got 4 in about 45 miles. I got the truck with 81,000 on it and have always used premium gas. I have no idea as to what to check next. HELP!!
Old Aug 11, 2010 | 06:43 AM
Rovin4life's Avatar
intake gasket is probably leaking by. I would have the vehicle smoked to make sure there are no leaks.
you have an air leak.
Old Aug 11, 2010 | 08:00 AM
agreed. smoke test that sucka.
Old Aug 11, 2010 | 02:56 PM
BIG g's Avatar
Thanks for the pointer. At the risk of sounding dumb, what is a smoke test and where do I take it to get tested?
Old Aug 11, 2010 | 03:06 PM
sito007's Avatar
tagged
Old Aug 11, 2010 | 04:05 PM
timdunbar's Avatar
Land rover dealership could do it. They will pump smoke into your intake and see where the leaks are.
Old Aug 11, 2010 | 05:57 PM
no no no... you can find a mechanic that will do it at half the cost or less than the dealer. or you can do it yourself with a cheap fog machine from a party store. try and get a colored liquid fog to make it easier to identify where the leak is.
Old Aug 11, 2010 | 06:16 PM
timdunbar's Avatar
ah sweet idea.
G,Demro
Jan 20, 2012 09:06 PM
jhewitt1111
Feb 16, 2011 03:11 PM
BIG g
Jul 26, 2010 04:43 PM
DEEBEE060
Aug 19, 2009 04:39 PM
dewhorse
Oct 29, 2008 01:00 PM
