Code 1316
Code 1316
Initially 306 & 305 came along with 1316..changing plugs and wires cleared 305. A faint popping could be heard out the exhaust..sounds great under the hood. My problem is a miss, stutter like running out of gas (occasionally the speedo drops to zero and may or may not start working again when the chugging stops) when reaching 45 & above. Usually only lasts a few seconds. Running injector cleaner every other tank of gas usually works. But am thinking a new injector might be needed on #6. Also, the fuel filter cannot be removed to change it.. I mean it's like somebody welded it on. Wondering about bypassing? Fuel pump is running about 30-34... suggestions?
