Sponsored by: CARiD
DiscoI Misfire 1316 code
Old Apr 24, 2010 | 01:42 AM
osolupo's Avatar
Default DiscoI Misfire 1316 code
1996 Disco - 130k miles.
Recently had the engine rebuilt at my construction equipment shop. Eveything went well, except check engine light was on and engine idled and ran rough.
I put new plugs and wires, compression was perfect. Still ran rough. Took it to the local Rover Shop to get it fine tuned. They quickly "determined" that it needed a new coil pack. $1,000 and enormous aggravation later. The engine runs just as rough. They put it back on the scanner and got a 1316 code and went on to list all of the possible problems. I was very discouraged with their lack of professionalism and honesty (extremely poor attitude to top it off).
So know I am trying to find an honest answer to get the vehicle running smooth.
Any help would be greatly appreciated.
Old Apr 24, 2010 | 05:58 AM
hilltoppersx's Avatar
is your CEL on? bring us the 4 digit fault codes
Old Apr 25, 2010 | 09:21 AM
osolupo's Avatar
The CEL light was on. The scan gave a code of 1316. The shop cleared the code and it has not come back on yet.
This seems to be the pattern. The code gets cleared. Engine runs fine for a few days, running a bit rough occasionally. Then it will run rougher at some point and the CEL will come on.
Old Apr 25, 2010 | 10:49 AM
what brand and size plugs and wires did you use?
are you hearing any ticking?
you should start with 8mm magencor wires and some nice Bosch +4 plat plugs, run a can of seafoam in tank.
Old Apr 26, 2010 | 01:45 PM
osolupo's Avatar
Plugs - Bosch Super Plus - Size - 13/16" Rover OE plug
Wires - Karlyn STI 663 - Don't know the size of the wires (Part Number: W0133-1622376 - purchased from partsgeek.com)
I do have some ticking. I have been told it is coming from cyl #7. Pretty sure it is the lifter.
I will try the Seafoam as you mention and let you know.
Do you still think I should change the plugs and wires? What is a good place to buy them?
Thanks.
Old Apr 26, 2010 | 02:36 PM
1316 is an excessive emission misfire. Send me your number and I'll call you.
best4x4byfar
Jul 3, 2012 07:59 PM
Townie
Jun 3, 2011 11:38 PM
osolupo
Aug 20, 2010 08:47 PM
sdsilvere38
Jan 13, 2009 07:12 PM
FJL
Oct 27, 2008 06:53 PM
