code and abs light
Old Feb 9, 2008 | 12:13 PM
loic's Avatar
Default code and abs light
I got my code read this morning for the 3 amigos, the guy cleared them but the 3 light came right back..
the code are : 1590 and 1300 there was also P0303 and P0305 (which if I rmember are the misfire )
what are the first 2 codes and does that mean I need to change the abs sensor ?...
Old Feb 9, 2008 | 01:18 PM
Default RE: code and abs light
http://www.troublecodes.net/landrvr/
The ABS sensor could just be loose or really clogged with brake dust. Oddly enough dirty ABS sensors trigger fault codes on a off-raod trk.
Old Feb 9, 2008 | 02:05 PM
loic's Avatar
las time I changed my rotors and pads (front only) I cleaned the sesnsors but did only the front sensor. could it be as simple as the rear being dirty ?
Old Feb 9, 2008 | 07:43 PM
okdiscoguy's Avatar
YOu need new plugs and wires. Magnacor 8MM and Bosch +4. The first code is a rough road signal and the last 3 are mis fires. What grade of fuel are you running? Might consider an induction cleaning as well.
You have to have a Rover compatible scanner to read the ABS codes. Totally different. YOu have 2 situations going on.. Have someone with a rover scanner read your ABS codes and it will tell you which sensor to look at. A regular OBD2 scanner will not read or clear ABS codes..
Old Feb 9, 2008 | 08:01 PM
ORIGINAL: loic
Yes it could be.
Old Feb 10, 2008 | 12:01 AM
loic's Avatar
so, when I asked those guy if they had a scaner to check the abs, and they say yes, they actually did a regular ODBII scan ?
Old Feb 10, 2008 | 12:03 AM
loic's Avatar
ORIGINAL: okdiscoguy
I'm running premium only, I added last week an Injector cleaner (lucas something) usualy I'm getting gas from Exxon or Shell. I knew about the plugs and wire.
Old Feb 10, 2008 | 09:48 AM
None of those codes have anything to do with your ABS, which does tak a much more expensive scanner to check, repair and clear.
First thing you need to do is the plugs and Magnecor wires, then you can clear the check engine codes.
Then find a shop with a lap top type scanner and get the ABS faults read and get back to us with what they find.
tibyABv6
Dec 17, 2011 01:10 PM
sayeedA
Nov 15, 2011 11:02 PM
marlymarl
May 28, 2011 10:34 PM
Brad S1
Oct 26, 2006 08:53 PM
