code analysis
Old Sep 26, 2014 | 08:14 AM
Sarge103's Avatar
Default code analysis
Well did my first long run with my new disco and of course CEL came on I put my scanner on it and pulled these codes.
P1590- ABS rough road signal malfunction
P0135- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0155- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0171- Multiplication injector adaptive fuelling lean limit exceeded LH bank
P1171- Oxygen Sensor System Too Lean Fault Banks A & B
P0139- Oxygen Sensor Slow Response *Codes* A D
im taking it that i need to replace my o2 sensors but i was wondering if I should just do all 4.
Old Sep 26, 2014 | 08:36 AM
Jared9220's Avatar
I think you are right on the money with getting new O2's. Before you go spend the money it's worth it to have a look at the 2 front O2 plugs. They can get oil inside them from a leaking valve cover and cause all sorts of problems.
If you decide to get new sensors then I would go ahead and replace all 4 sensors from bosch. If you can't afford all 4 bosch then just get the front 2 bosch right now and the rear 2 down the line, but what ever you do I would stay away from aftermarket sensors.
Old Sep 26, 2014 | 08:38 AM
Sarge103's Avatar
If the plugs are dirty what do you recommend I use to clean them? Just some electrical cleaner? If the cleaning doesn't work I'll do 2 now 2 later
Old Sep 26, 2014 | 08:41 AM
Jared9220's Avatar
Yeah, some kind of sensor spray like MAF cleaner or electrical cleaner.
Old Sep 26, 2014 | 09:42 AM
Sarge103's Avatar
By the way woukd bad o2 sensors cause a rough idle?
Old Sep 27, 2014 | 07:29 AM
parke's Avatar
Yes the O2 sensors will cause a rough idle, I am going/went through the same issues. Only I had 15 codes!! If you haven't already I would recommend upgrading to Magnecor 8mm plug wires:
Amazon.com: Magnecor 80242 8mm Electrosports-80 Ignition Cable 1999-2004: Automotive Amazon.com: Magnecor 80242 8mm Electrosports-80 Ignition Cable 1999-2004: Automotive
As instructed to me by DiscoMike. Good luck!!
Old Sep 27, 2014 | 08:14 AM
Sarge103's Avatar
Ok yeah my wires say leoni on them
Extinct
Oct 25, 2014 04:59 PM
hatt53
Mar 27, 2013 05:16 PM
sayeedA
Nov 15, 2011 11:02 PM
krazzz
Mar 5, 2010 10:45 AM
ryanD2
May 13, 2009 09:30 PM
