Code help
Old Oct 20, 2012 | 07:51 PM
chermecz's Avatar
Lightbulb Code help
changed out coils,wires,and plugs cleared misfire codes...new codes showed up a day later..
any help on these
thanks in advance
0734-gear ratio incorrect
0174-system too lean bank 2
0171- sytem too lean bank 1
Old Oct 20, 2012 | 08:03 PM
jafir's Avatar
Probably a bad maf. Try cleaning it with crc maf cleaner. Let it dry completely before plugging it back in.
Old Oct 20, 2012 | 08:13 PM
lr2001silver's Avatar
Banned
X2
Also is your mass air flow a Bosch of another brand? Make sure your maf is plugged in all the way.
Old Oct 21, 2012 | 10:04 PM
chermecz's Avatar
Its a Bosch maf and I replaced it about 6 weeks ago ...I bought it used from an ebay parts source...I had a maf code before and these other codes did not exist then..I will try cleaning it as you said..
Thanks
Old Oct 22, 2012 | 08:08 AM
And don't get too confident, many of these style codes have to happen two or four drive cycles before they cause light to come on again. A week of everyday driving is when to relax a little.
Old Oct 22, 2012 | 09:39 AM
Hard way to learn not to buy a used MAF.
Go for a new one, that is what the codes are showing as being needed. Might consider British Parts of Utah, they have a good price on their new replacements.
Old Oct 22, 2012 | 10:30 PM
chermecz's Avatar
Thanks fellas the light is coming on every so often...I keep clearing it..I will order a new MAF..thanks as always..
Old Oct 23, 2012 | 12:22 AM
aarongregor's Avatar
I learned to never clean your Bosh MAF, I learned the hard way. I bought a new one for $199 and I when I was a newbie did not clear the codes so I decided to listen to the parts store and bought some MAF cleaner and 2 days later was paying another $199 for another MAF. When some of the people say clean it DO NOT! I guess if its already shot you have nothing to lose but that cleaner eats them alive.
Old Oct 23, 2012 | 12:52 AM
Banned
Cleaner only "eats it alive" if you douse the hell out of it but if you lightly spray it will not harm it one bit i clean mine all the time and never have any problems.
Old Oct 23, 2012 | 04:04 AM
And it is very important to clean it when the sensor is cold. When ignition is switched on to allow you to listen to the ball game while you work; some MAFs heat a spot inside to 350F above ambient. It does not like cold spray at that point, even a tiny squirt. More of wallet drain on a D1. But I clean the MAF my Disco, and Mercedes, and Kia - all with the CRC spray.
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
