code p0741
My only couple of suggestions are, first count the number of times the tranny shifts, you should feel 4 shifts1st to 2nd, 2nd to 3rd, 3rd to 4th and then the torque convertor locking up.
Consider draining the oil again just to get you fluid even cleaner and add a bottle of Lucas tranny additive along with the ATF to help free up any potential stuck valves.
Then if you are still having problems, have a Rover mechanic that has a scanner that can read real time tranny problems diagnois what is happening.
Good luck,
Mike
Good luck,
Mike
