code p0741
Old Dec 8, 2006 | 10:30 PM
Tanrover's Avatar
Default code p0741
Hi folks, I'm having fun with my rover again. Has anyone ever had the code p0741 before and if you have, what does it mean?
Thanks
Old Dec 8, 2006 | 11:21 PM
Default RE: code p0741
Not the best of news, P0741 Torque Converter Clutch Circuit Performance or Stuck Off.
How many miles on your truck, how often do you service the tranny?
Mike
Old Dec 9, 2006 | 08:44 AM
Tanrover's Avatar
Hi Mike,
The truck has 73000 miles on it. I just changed the transmission fluid in the case only. I'm not sure if it has ever been done before.
Thanks
Old Dec 9, 2006 | 11:27 AM
My only couple of suggestions are, first count the number of times the tranny shifts, you should feel 4 shifts1st to 2nd, 2nd to 3rd, 3rd to 4th and then the torque convertor locking up.
Consider draining the oil again just to get you fluid even cleaner and add a bottle of Lucas tranny additive along with the ATF to help free up any potential stuck valves.
Then if you are still having problems, have a Rover mechanic that has a scanner that can read real time tranny problems diagnois what is happening.
Good luck,
Mike
skunkridge
Sep 17, 2024 05:47 PM
Fast951
Mar 11, 2015 09:21 AM
Thatdudeuno1
Dec 30, 2014 04:06 PM
rod76
Feb 28, 2010 11:18 AM
ngv151515
Sep 28, 2009 05:18 PM
