Code: P1453
The evap system uses a small electric pump. The system tests the pump against and detects leaks as small as .02 inch by low pump current, and blockage by high current. In your case the pump current has exceed 40 milliamps, and this is one of the codes that can be cleared, then take four driving cycles to re-appear. Probably a bad DMTL pump (Diagnostic Module Tank Leakage). See attached.
Not sure what is going on with your wire, but a coil with zip ties is not stock.
Heres one for a Rover, may have to call AB and ask them the variation for your truck.
Land Rover Fuel System Parts | Pump - Evaporative Loss Leak Detection - Diagnostic Module Tank Leakage System (DMTL)
Wow this is a flashback. This has to be one of my very first post on here. Shame on me for not posting the fix.
Anyway, I had a bad leak detection pump. Here is the new part from AB: Pump Evap. Loss Leak Detection (Genuine Part # WTR000010) - Land Rover filler caps from Atlantic British
DiscoBenjamin
Oct 14, 2011 05:53 PM
